Edited by donor10, 01 January 2012 - 12:17 AM.
Flare Gas Recovery System Setup
Started by donor10, Dec 30 2011 12:28 PM
No replies to this topic
Posted 30 December 2011 - 12:28 PM
Dear all I am woking for flare gas recovery (FGR) project and already had some idea. I must understand more information to plan overall system. Some idea need advise. (1) We should use the liquid ring compressor (LRC) to recover flare gas according to vender's presentation, ex JohnZink. Is there any user's experience? I hope that anyone shares the operating experience of LRC in control or maintain, etc. (2) Our control sequence is FGR, ground flare and elevated flare based on flare header pressure. Any actual experience is such? (3) Generally, how many temperature is the gas outlet for the liquid ring compressor type? (4) How many volume flow is the liquid blowdown when liquid ring compressor oparate? (5) if setting three liquid ring compressors, is it appropriate for multi stages control? My idea is that the stage refers to header pressure. (6) Can the liquid ring compressor resist the flare gas including H2S? how many percentage is the allowable H2S concentration? I am very appreciative for anyone's reply.
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , Yesterday, 01:25 AM |
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
Flare Header Reverse FlowStarted by Guest_Ahmadhamzahperta_* , 04 Apr 2025 |
Psv For Refrigeration SystemStarted by Guest_runnerup_* , 30 Jun 2025 |
Parallel Compressor Setup With Uneven CapacitiesStarted by Guest_sinrem_* , 13 May 2025 |
