hi
I am going to redesing a control valve for acetic acide service which is located in below condition.
can anyone tell me the correct calculeted "Cv"?
flow rate:270m3/h
inlet pressure:28 bara
outlet pressure:5.94bara
inlet temperature:185c
specific gravity:0.9035
vapour pressure:28bara
best regards
rohollah
Calculated Cv
Started by rohollah, Jan 02 2012 05:46 AM
Posted 02 January 2012 - 05:46 AM
Posted 02 January 2012 - 10:15 PM
Dear rohollah
Yours is a flashing service, refer this page for step by step sizing guide
http://blackmonk.co....-control-valve/
Posted 03 January 2012 - 07:39 AM
Probably vapor pressure needs further check, being about 5.4 bar a for pure acetic acid at 185 oC, http://en.wikipedia...28data_page%29 .
"Manual" calculation is tried in attached "CV.xls", following Masoneillan. Method seems similar to the proposed by DB Shah (with small differences). Comments on the attachment would be welcomed, as well a result by an instrument software for comparison.
Assuming critical pressure = 57.8 bar a (that of acetic acid), calculated Cv at conditions is
Cv=129 gpm/sqrt(psi) for vapor pressure = 28 bar a (this does not seem to be for acetic acid).
Cv=68 gpm/sqrt(psi) for vapor pressure = 4.5 bar a.
Last result is practically same as the one by brondy in post No 2.
Posted 03 January 2012 - 01:24 PM
rohollah,
An excel spreadsheet for control valve sizing based on Masoneilan method can be downloaded from the following link:
http://www.google.co...FrCjAPw&cad=rja
Posted 04 January 2012 - 02:49 AM
![]() How Is The Performance Of The Distillation Tray Calculated? The DistanStarted by Guest_Ahmedforup_* , 11 Oct 2024 |
Bubble Point Calculated For Shortcut Differed From Aspen PlusStarted by Guest_rosesdaf_* , 14 Apr 2022 |
![]() Orifice Plate Measuring Flow Away From Calculated Value!Started by Guest_Fatema1987_* , 08 Mar 2022 |
![]() How To Calculated Pump For Wet ScrubberStarted by Guest_thuyetle_* , 29 Sep 2020 |
How Can Heat Of Reaction Be Calculated In Hysys?Started by Guest_stratovona266_* , 25 May 2017 |
