Fire Fighting System
Started by Narnia, Feb 06 2012 01:23 AM
8 replies to this topic
Posted 06 February 2012 - 01:23 AM
I am very much new in field of fire detection,fighting and safety system etc. As a beginner i have to just only list down the complete list of items (hydrants,monitors etc) now only. please share some information on it so that i will compile complete list of above items
Looking for very prompt respnse.
thanks
thanks
Posted 06 February 2012 - 02:17 AM
Narnia,
For an introductory understanding of fire protection systems refer the book:
Introduction to Fire Protection by Robert W. Klinoff
Also two NFPA standards should help you in understanding "Fire Water" systems.
NFPA 15 - Standard for Water Spray Fixed Systems for Fire Protection
NFPA 20 - Standard for the Installation of Stationary Pumps for Fire Protection
Hope this helps.
Hope this helps.
Posted 06 February 2012 - 02:56 AM
Yes i will review these standards in some advanced stage , Now i just want to know list of items which are normally required for fire system
Posted 06 February 2012 - 08:49 AM
Posted 08 February 2012 - 12:59 AM
Dear Narnia
I will suggest you to go through the standards referd by ankur & ZAK, as only listing down the items will not help you much.
Typicaly firefighting system consist of
1. Fire pumps
2.Booster pumps
3. Fire hose reels.
4. Fire / foam monitors
5. Foam generator/ foam tank
6.Fusible plugs for detedtion
7. Spary nozzle
8. Pnumatic shutdown valves
9. Fire alarms (audio/ visual)
10. CO2 flooding system
11. Inter gas blanketing system
May be I have miised somthing but hope this will work for you..
1. Fire pumps
2.Booster pumps
3. Fire hose reels.
7. Spary nozzle
Posted 15 April 2012 - 09:35 PM
Dear All
Could you please tell me about fire fighting system for Gasoline storage tank(6000m3) & Heavy Fuel storage tank(5000m3) & Diseil storage tank(6000m3)??
do they need to ant special fire fighting system????
Best Regards,
HYPER
Best Regards,
HYPER
Posted 16 April 2012 - 06:46 AM
Hyper ,
Consider this resource to support your query .
You should consider to take a look at the MSDS of the products and risks associated
Using the search button you will find much more .
An other point to consider is the insurance and their requirement , same for local administration .
Hope this helps
Hope this helps
Posted 16 April 2012 - 08:56 AM
In addition to web reference mentioned by Breizh, following can be useful as an introduction.
http://www.cheresour...n-storage-tank/ '> http://www.cheresour...n-storage-tank/ .
http://www.cheresour...-a-storage-tank '> http://www.cheresour...-a-storage-tank .
Posted 16 April 2012 - 11:49 PM
Hyper ,
Consider this resource from which you can download many standards (IPS) . This will certainly help you and others who have lack of resources.
Just google the name of the standard you want .
Lime SystemStarted by Guest_Dorota86_* , 01 Mar 2025 |
![]() Psvs Relieving To Closed Drain SystemStarted by Guest__1angelia23_* , 12 Jan 2025 |
![]() Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
![]() Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
