Water Flowrate In Piping Tee-Off
pipe flowrate tee off water
10 replies to this topic
#1 Low
Low
  • 21 posts
Posted 13 February 2012 - 03:51 AM
I would like to know how should I make a educated guess about whether my water flow rate at the outlet is sufficient.
Fluid: PCW
Temp: 12-15C
Pressure: 5 bar
flowrate in the main header, 16" = 300-400 m3/h
Final outlet pressure: 4 bar
Required flowrate: 1 m3/h
We are going to hot tap a 6" pipe and I am tasked to find out if a 1 1/2" hot tap would suffice. At the moment the plan is to tee off each 1 1/2" pipe to supply for 2 units, meaning each hot tap will be supplying two units.
From 1 1/2" the pipe will be reduced to 1/2", passing through a ball valve, and then finally the outlet would be 3/8". The required final flowrate for the 3/8" outlet is 1 m3/h, and the outlet pressure is about 4 bar.
From the mainline flowrate it would seem like enough but I would just like to make sure.
Just to add, everything is existing and the only part we are adding would be from the 1 1/2" pipe onwards.
So to conclude, I would like to know if my flowrate obtained from the 1 1/2" pipe is sufficient, or do we need a bigger pipe, and how did you come about getting the figure.
Appreciate the help.
#2 Low
Low
  • 21 posts
Posted 13 February 2012 - 07:32 PM
Also how do you calculate the flowrate in an equal tee? Divide the flowrate evenly? And for a reducing tee you divide it using the ratio of their radius? Because if I use this method I barely have enough water for less than a quarter of the plant, so something must be wrong with my calculations/assumptions.
#3 vikramltv
vikramltv
  • 52 posts
Posted 14 February 2012 - 12:02 AM
It will be better if you attach a scketch for you sceme elaborating your problem..
#4 Low
Low
  • 21 posts
Posted 15 February 2012 - 12:05 AM
Will do.
#5 breizh
  • 6,735 posts
Posted 15 February 2012 - 01:00 AM
You can dowload from Internet a software called PSIM ( pump system improvement modeling tool ) which can support your query . As stated , you must define your sketch first.
Hope this helps
#6 Low
Low
  • 21 posts
Posted 15 February 2012 - 04:41 AM
Sketch attached. Appreciate the help.
#7 Low
Low
  • 21 posts
Posted 17 February 2012 - 12:56 AM
Anyone know how to use the PSIM?
EDIT: I can't really define my sketch in the PSIM because it only allows 12 pipes and 24 junctions, and both upstream and downstream of each junction have to be defined. I don't think it's enough for me, unless I am doing this the wrong way. Forgive me, I have no prior experience with piping software.
Edited by Low, 17 February 2012 - 01:26 AM.
#8 breizh
  • 6,735 posts
Posted 18 February 2012 - 01:46 AM
let you use the examples and manipulate the input data and run the program , you should understand (From simple to complicated ones).
For each pipe you need to provide diameter , rugosity , altimetrie .
It's really home work .
#9 vikramltv
vikramltv
  • 52 posts
Posted 19 February 2012 - 10:48 PM
I have not used PSIM, But I had solved the similar problem with PIPENET that requires flow or pressure inputs at end points. It will size your line in design mode once you give the fitting , elevations and end point pressure/flow. get a copy of it and it will surely do wt you need..
#10 Low
Low
  • 21 posts
Posted 28 March 2012 - 07:31 PM
Hi guys thanks for the valuable input.
#11 S.AHMAD
S.AHMAD
  • 786 posts
Posted 29 March 2012 - 03:05 AM
1. We need to know the piping configuration - pipe length, fittings, elevation etc
2. Use line pressure drop equation to determine the flow rate
