I'm looking for some assistance regarding a calculation.
The gas flow rate across a PCV for a PSV sizing calc is what I'm having problems with. A high pressure vessel vents to a low pressure vessel through a PCV (details in spreadsheet). I've calculated 313Nm3/hr as the volumetric flow rate. However I've found some design documents, which while not kind enough to specify how they've reached this figure, indicate that it is to high. I should be getting an answer below 250Nm3/hr apparently.
If anyone might take a look at the attached spreadsheet and see if I have correctly calculated the flow rate across a Cv=4.4 Cg=156 valve from 550kPaa to 220kPaa for pure N2 service that would be greatly appreciated.
Thank you.
