Hi everyone,
I am chemical engineering student trying to design a desalination plant using Aspen. I have just started and for the whole day, this error message keep coming up and I could not generate any result from my model:
QUERY BLOCK B2
The engine cannot interpret the command:
QUERY BLOCK B2
<< Problem specifications modified 17:13:39 Fri Feb 24, 2012>>
->Processing input specifications ...
*** SEVERE ERROR IN A "BLOCK" PARAGRAPH
BLOCK NAME: B2 MODEL NAME: FLASH2
THIS BLOCK DOES NOT APPEAR IN ANY FLOWSHEET PARAGRAPH.
PARAGRAPH IGNORED.
->Finished processing new specifications
! Errors while processing input specifications
QUERY BLOCK B2
Can anyone tell me what am I doing wrong or how could I solve it ? Block 2 is simple a Vertical 2-Flash, and I fed the output from a distillation column to the flash. I tried to upload my model here but failed. Hope you can help. many thanks.
thanks.
Aspen Plus Error Message
Started by kimhywu, Feb 24 2012 12:20 PM
Posted 24 February 2012 - 12:20 PM
Posted 25 February 2012 - 12:04 PM
attach your simulation file here,i can't understand what's the problem with your explains
Posted 27 February 2012 - 05:53 AM
Sorry for being stupid,
how can I attach my stimulation here?
many thanks
many thanks
Posted 19 March 2012 - 11:15 AM
Bro have you entered the account name in your setup, in some case i have got this problem but it was rectified when a account name is give. you can place any name.
go to DATA>setup>accounting
type something at user name.
before doing this is your flow sheet is completed. if not you cannot enter
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Aspen Plus Conceptual Mof Synthesis Model: Elecnrtl, Ionic Leachate, PStarted by Guest_Momo_212_* , 16 Apr 2026 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
