I am working in ammonia production. We are facing gas limitation problem. Frequent Load adjustment is required. We need parameters adjsutment. It takes a lot of time to completely tune the plant.
Any one have better option for parameters tunning
Ammonia Plant Optimization With Frequent Load Change
Started by waheedbhatti, Feb 27 2012 10:24 AM
Posted 27 February 2012 - 10:24 AM
Posted 18 March 2012 - 05:14 AM
Waheed,
This is a typical plant operation issue. The best way to handle this is to put your various controllers like NG Feed control,S/C ratio control,Air/gas control, reformer firing etc in automatic control mode. If the variation is too much, you might need to do proper tuningof various controllers to respond to the variations. If you still need better control and economy, you should go for APC.
I am sure your plant operation people are smart enough to handle such variations.
If you provide some snap shots and trends of your plant datas, I can help you.
Kind regards,
Satyajit
Kind regards,
Satyajit
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
