I would like to know if anybody may help me in to get data for vapor liquid equilibrium for ethylene oxide-water system.
Best Regards for all,
wnovaes.
Vapor Liquid Equilibrium Data For Ethylene Oxide-water System
Started by Guest_wnovaes_*, Oct 13 2005 09:33 PM
Guest_wnovaes_*
Posted 13 October 2005 - 09:33 PM
Guest_Martin Sneesby_*
Posted 26 October 2005 - 05:40 AM
Try DECHEMA at your local university library. Otherwise, any of the major commercial engineering simulators will have data for EO-water, which is likely to be trustwrothy for such a commno binary. I've modelled EO columns in Hysys and found the VLE OK.
Advanced Process Engineering & Simulation Services
Posted 27 October 2005 - 03:49 PM
Martin Sneesby,
Frist, thanks for the reply.
But, I tried the Aspen Plus Simulator and it has the DECHEMA within its library. However, the results of VLE calculations were not so good for middle and high concetration of Ethylene Oxyde in water.
Best Regards,
wnovaes
Best Regards,
wnovaes
Posted 01 November 2005 - 03:08 AM
Are you using an appropriate thermo package like NRTL? The DECHEMA database (and any others) is based on experimental data so should be reliable. However, this data still needs to be fitted to a thermodynamic model, and this can introduce errors itself. If the choice of thermo is inappropriate, the parameter fiiting won't work well.
You have indicated a mismatch at mid-high concentrations of EO - does this mean you have your own experimental data? If so, you can always fit your own VLE parameters with a tool like Aspen Plus.
If you are comparing your modoel with plant data, are you sure that your other assumptions are correct? Perhaps its not the EO-water VLE that is generating the mismatch, but the presence of some other components. Are you comncentration and temperaure measurements accurate? Etc.
Ethylene Oxide Off-SpecStarted by Guest_Movers_* , 25 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
