Dear Members,
I would like to know what would be the minimum informations required for the designing of submersible pumps
1. flow
2. required pressure
3. service fluid
4. driver
is there some other informations required
how these pumps are normally installed.
thanks
Submersible Pumps
Started by Narnia, Feb 29 2012 05:26 AM
Posted 29 February 2012 - 05:26 AM
Posted 29 February 2012 - 12:50 PM
Narnia:
What you lack is a normal and conventional manner of describing the pump you require. The means to attain that is called a Pump (Centrifugal?) Data Sheet. This is the instrument by which all engineering companies and pump manufacturers convey the information required that identifies the service and characterisics of the subject pump.
In the past I have uploaded into our Forums a workbook full of formal Data Sheets for process equipment and instruments for the purpose of making these available to our members. Among this collection is one for Centrifugal Pumps. Presumably your submersible is a centrifugal type. Use the Forum's Search machine and you can find the thread where you can download the entire workbook.
Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Design Considerations For Cryogenic Submersible PumpStarted by Guest_heydari_* , 04 Feb 2024 |
Vibration Of The Pump (Reciprocating Pumps / Plunger Pumps)Started by Guest_vsedhuraman_* , 06 Oct 2023 |
Variable Speed Pumps Operation.Started by Guest_panoska_* , 11 Oct 2022 |
