Hi, i am an engineering student, and i am working on a cross flow induced draft cooling tower. I am stuck in the design calculations. I know the inlet and outlet temperature of water, volume flow rate of water and the heat load desired from the cooling tower. Is it possible to perform the complete calculations with these parameters? If not then what other parameters would be required? Please help me out. Thank you.
Cooling Tower Design Calculations
Started by hasanaskari_14, Mar 13 2012 02:37 AM
Posted 13 March 2012 - 02:37 AM
Posted 13 March 2012 - 03:04 AM
Hope this helps .
An other resource is Perry's chemical engineering handbook..
Posted 15 March 2012 - 10:24 AM
Thank you for the help. I am using the sample calculations given in the following pdf. I want to know if it is applicable for an induced draft cross flow cooling tower. If it is applicable, then is it possible to get characteristic curves for the loading factor? The curve provided does not fit my data. Thank you
Cooling tower calculation.pdf 855.18KB
885 downloads
Posted 09 January 2013 - 08:15 AM
Hi, there
Is there any web applicaion for design calcuation of cooling tower, like if i put the size it will give me the detailed design. So that it will help me to quot my clients.
Posted 11 January 2013 - 10:56 AM
Baltimore Air Coil (BAC) has some design manuals which may be of interest. I cannot remember if I needed permission to download them. Also Marley Cooling Towers (made by SPX) has some items in their library (http://spxcooling.com/en/library/)
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
