What if my hysys operating pressure differs from the operating pressure of Mellapak Plus design that is given by Sulzer brochure?
Mellapak Plus Design
Started by Teck Guan Wan, Mar 21 2012 03:22 AM
Posted 21 March 2012 - 03:22 AM
Posted 21 March 2012 - 05:17 AM
Hi Teck,
First of all, change in pressure does affect the sizing of tray/packing due to change in fluid properties. I have reviewed numerous quotes from trays/packing vendors including the most renowned Koch Glitsch and Sulzer. I am confident that these vendors make use of the properties provided by you for sizing purpose. I have also used propriety vendors' softwares. These softwares require bottom pressure input only to report top pressure by subtracting pressure drop. Therefore, the pressure input in these softwares has no effect on sizing. Bottom line is that you should assess the change in properties of the fluid due to change in pressure. You can use the simple procedures described in literature (e.g. Souder Brown's equation with appropriate K-Factor from vendor's brochure) in order to determine the extent of change in sizing. So just match the properties with the vendor's brochure. Even if the vendor has used different pressure and your properties are good, nothing is going to change.
Edited by P.Engr, 21 March 2012 - 05:25 AM.
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
