I have a case in which DIPA is used in an extractor to absorb H2S from propane, but because the propane is sweet, the DIPA absorbs the propane. My question is: Why does the DIPA absorb the propane? I want to know the reason behind it.
Dipa Amine
Started by Aylool, Mar 21 2012 06:40 AM
Posted 21 March 2012 - 06:40 AM
Posted 25 March 2012 - 10:39 PM
While propane is very slightly soluble in amine, I suspect that what you are observing is entrainment of propane droplets with the "rich" amine. I observed this 20 years ago at a plant in Canada.
The problem comes from a poor inlet distributor design, or velocities in the column above acceptable levels. You may be atomizing the propane into the amine, and the amine velocities are carrying these small propane drops out the bottom of the column (because they are too small to rise rapidly enough).
Check your propane distributor - the holes should be no smaller than 0.375" and velocity out of the holes should not exceed 1.25 ft/s. You should also do a stokes law calculation on the amine below the propane distributor to check what propane droplet size can rise against the amine flow.
![]() Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
Dp Drop In Structured Packing Amine Absorber Causing IssuesStarted by Guest_kek12345_* , 10 May 2024 |
![]() Amine System FiltrationStarted by Guest_Hanaa_* , 09 Jan 2022 |
Rich Amine Quality In Lpg Absorber TowerStarted by Guest_Alchemes_* , 21 Nov 2022 |
![]() Foaming In Amine UnitStarted by Guest_Alaa55_* , 31 Oct 2020 |
