Hi there,
Does any one has any vendor information regarding how much air will required to produce 2000 Nm3/h 99.99% pure Nitrogen + 400 Nm3/h Liquid Nitrogen (Gaseous Equivalent) ?
Thanks in advance.
Mitul
Air Separation Unit - Air Requirement For Producing 99.99% Nitrogen
Started by , Mar 22 2012 08:55 AM
Posted 22 March 2012 - 08:55 AM
Posted 22 March 2012 - 10:32 AM
I am also searching for the answer to this question, mine is just 1000 nm3/hr
Posted 15 August 2012 - 03:16 AM
By rough calculation, for nitrogen plant, total nitrogen recovery not very high. I think it depend on how much gaseous nitrogen produced. More gas produced mean higher recovery. Maybe you can use around 30-40% recovery if there is gaseous nitrogen product. If there is no gaseous product, try use 10-20% recovery.
CMIIW.
CMIIW.
Posted 22 August 2012 - 04:35 AM
If you need liquid nitrogen as a product at high purity and high production rates (which is the case), you may need a cryogenic separation plant. You can find very useful information in the following link, just take some time to go trough the website and read:
http://www.uigi.com/index.html
I hope this helps.
I hope this helps.
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Nitrogen Capacity Tankfarm During WinterStarted by Guest_jango_* , 03 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
