Looking For A Good Phase Behavior Modeling Software...
phase behavior
#1 Mark Thomas
Mark Thomas
Posted 22 March 2012 - 02:48 PM
Hello all,
I am new here. I am searching for a robust HIGH PRESSURE VAPOR-LIQUID EQUILIBRIUM calculator.
Ideally, it should be able to calculate a phase diagram for matrices consisting of up to thirty or so components.
Additionally, I need to be able to add new compounds as well as the critical properties for each to the software.
I work with many more compounds than are simply found in natural gas.
Can anyone recommend software that can handle this?
Thanks in advance,
Mark
#2 J_Leo
J_Leo
  • 262 posts
Posted 22 March 2012 - 09:29 PM
Calculator?
We use simulation softwares, like ProII, Hysys to perform this kind of tasks. But these softwares are pretty expensive.
#3 Mark Thomas
Mark Thomas
Posted 23 March 2012 - 03:19 AM
I'll check them out. Thanks.
Any others?
#4 marchem
marchem
  • 153 posts
Posted 23 March 2012 - 05:22 PM
Unfortunately even very expensive simulators may suffer convergence errors in some areas of retrograde region, typically when close to critical point, you may test a series of mixtures and for each mixture generate a phase envelope plus critical point then do a series of isothermal flash at different distances (say 0.1 - 5K 0.1-5 Bar) from critical point in all directions, most common error being a single phase detected instead of vapor + liquid, other common errors being for properties as isothermal compressibility, cv etc.
If you have that possibility I would recommend to compare different products and make your own opinion, in the list, in addition to the above mentioned simulators I would include a good process library as Prode Properties.
#5 frpe
frpe
  • 47 posts
Posted 25 March 2012 - 10:39 AM
imho marchem is correct,
many engineers do not test VLE data for consistence, it would be a interesting area of discussion.
#6 Technical Bard
Technical Bard
  • 407 posts
Posted 25 March 2012 - 10:44 PM
Check out VMGSim from Virtual Materials. Good thermo people behind that product.
