Attempting to run a simulation in Aspen Plus. At one point I had added a combustion block (RStoic), but have since decided it was not needed. I attempt to delete the block in a number of ways (right-click delete; go to "Blocks" and select this block and delete; and deleting from the process flowsheet itself). No matter what I do, the block will not delete.
When running the simulation, I receive the following error:
*** SEVERE ERROR IN THE "BLOCK" PARAGRAPH WHICH BEGINS ON LINE 238
BLOCK NAME: COMB MODEL NAME: RSTOIC
THIS BLOCK DOES NOT APPEAR IN ANY FLOWSHEET PARAGRAPH.
PARAGRAPH IGNORED.
I am unable to generate a report due to this. Is there any way for me to solve this issue? I would hate to have to start fresh because one unnecessary block can't be deleted. Any insight is much appreciated!
Aspen Plus Severe Error Block Not Recognized
Started by sweetyo21, Mar 27 2012 07:30 PM
aspen severe error aspen error aspen block aspen delete block not recognized aspen severe aspen issues aspen simulation simulation error
Posted 27 March 2012 - 07:30 PM
Posted 27 March 2012 - 10:53 PM
could you upload your simulation?
Posted 28 March 2012 - 11:01 AM
I am trying to upload the Aspen file, but am being told I am not permitted to upload this type of file. I have tried .apw, .apwz, and .bkp, but none are permitted. Is there some other way for me to do this?
Posted 31 March 2012 - 02:11 AM
In such circumstances I would rather write to Aspen Support. They are very helpful and sometimes even admit to bugs. I am sure it will be quicker than trying to find somebody with similar experience in a blog
Posted 01 April 2012 - 07:10 PM
you should try to change the extension to .rar or something else..
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
![]() Help On Simulation Of Reactor In Aspen PlusStarted by Guest_m.ghaziasgar_* , 06 Jan 2025 |
