1. Thank you for sharing. The slide is very informative.
2. I seek your permission to use the slide contents for training young engineers.
Edited by S.AHMAD, 14 April 2012 - 01:01 AM.
Posted 14 April 2012 - 12:59 AM
Posted 14 April 2012 - 04:18 AM
Posted 14 April 2012 - 04:46 AM
Posted 14 April 2012 - 05:44 AM
Posted 15 April 2012 - 04:01 PM
Posted 16 April 2012 - 10:22 AM
Edited by kkala, 16 April 2012 - 10:32 AM.
Posted 16 April 2012 - 10:52 AM
Posted 17 April 2012 - 04:47 PM
Posted 20 July 2012 - 05:31 AM
As a conclusion from posts No 8 - 23, I believe that LPG spheres should have PSVs sized for fire on them. An exceptional case (if any) has to be decided after patient investigation in my opinion. References / specific examples of such cases were requested in posts No 20, 23 (para 4), 24, 29, without response (so far).
Of course additional measures should be also considered (emergency depressurization, water deluge or spray systems, etc). A PSV sized for fire may not be enough to avoid BLEVE, yet it is necessary as a last resort to delay it.
"After an accident, if you can convince the inspector that the relevant design had been according to accepted codes (or safety level was higher than their requirements) you get free of charge". I read something similar in the past, judged it right. So much care is necessary, even though improper operation or maintenance can be a more frequent cause of accidents than design pitfalls.
Note: I do not know whether PSVs sized for fire are mandatory on LPG spheres by code at any case.
Editing note, Feb 16 2013: <http://www.cheresour...age/#entry69308> could be useful to a reader interested in LPG vessel layout and fire protection.
Edited by kkala, 16 February 2013 - 12:36 PM.
Storage Tank Relief LoadStarted by Guest_hum464_* , 10 Sep 2025 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Sizing Fire Case Relief Valve Installed Below Liquid LevelStarted by Guest_processrock_* , 14 Apr 2026 |
Relief Path To Be Considered For Inlet Pressure Drop CalculationStarted by Guest_Ascanio E._* , 09 Jul 2025 |
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
