hi .. I have to design a washer cooler to cool and and wash ash particles of size -200mesh .. the gas is a minture of CO 55% H2 30% CO10% rest is N2 ,H2S .... gas enters the washer cooler at 350F and leaves at 100F and water at ambient condition is to be used ... about 90% of ash particles are removed ... since in this case heat transfer is the controlling step so i have decided to design it on the heat trasfer base .. but i am facing problems in desiging .. one thing is that i am able to find humidity chart for this type of a gas and if i use air humidity chart the wet bulb gas outlet temp falls below wet bulb temp ... please can anyone help me in this regard and give some hint on what type of scrubber i use and how to proceed the design ..
reply and thanks
Washer Cooler Design
Started by aliadnan, Nov 14 2005 11:41 PM
No replies to this topic
Posted 14 November 2005 - 11:41 PM
Slotted Pipe/diffuser DesignStarted by Guest_pratik_* , 02 Jul 2026 |
Design Of High Temperature Duct WorkStarted by Guest_tjsegan_* , 15 Jun 2026 |
Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 21 May 2026 |
Absorber And Stripper Design - Eqbm Data?Started by Guest_ChemEngBoy26_* , 03 May 2026 |
Adsorber Design Essay QuestionsStarted by Guest_Kahirn_* , 10 May 2019 |
