Delayed Coker Fractionator Problem
Posted 25 April 2012 - 11:26 PM
Column Details
No of trays : 37
Top temp: 100
Top Pressure: 1.6 kg/cm2..
Ck draw Temp: 180o
Top Reflux flow : 65m3/hr.
CK draw tray :29 (counting from the top)
Can anyone please explain this phenomenon.
Phukan
Posted 28 April 2012 - 09:04 PM
However, you appear to be seeing the opposite effect. A small amount of water could be creating a "stripping" effect - by lowering the hydrocarbon partial pressure in the top of the column. Heavier materials could then evaporate and end up in the coker naphtha.
Posted 08 May 2012 - 03:29 AM
In our delayed coker main fractionator, whenever water comes along with the top reflux (because of choked stand pipe of the boot leg interface level and hence wrong indication ), we tend to loose level in coker kero draw tray located 8 trays below. This phenomenon is also accompanied with decrease in the draw temperature. In fact, the first indication of water ingress with reflux is gradual decrease in its draw temperature, (other parameters remaining constant) followed by increase in stripper draw opening. Finally it settles down to a temperature of around 135o C with stripper opening of 100%. Whatever we may do - by increasing the top reflux or decreasing the heat load in HGCO PA section, we fail to get condensation in the coker kero zone. level can only be brought back once interface indication is properly rectified.
Column Details
No of trays : 37
Top temp: 100
Ck draw Temp: 180o
Phukan
As you mentioned in your post, the culprit as your overhead reflux drum interface level indication which puts water in the column along with HC liquid reflux. Have you ever operated column with field operators continuously monitoring the boot water level and draining manually.
Posted 30 May 2013 - 07:55 AM
we're currently working on the design of a delayed coking unit inside a refinery. I find it quite hard to start with the material balance because I cant find the composition of my feed (vacuum residue). all I have now is the amount of the feed. Can you help me out guys. Thanks.
Lng ProblemStarted by Guest_guoyinyanliner_* , 10 Dec 2025 |
Thermosyphon Reboiler ProblemStarted by Guest_aliebrahem17_* , 22 Oct 2025 |
Material Balance ProblemStarted by Guest_vinnay1999_* , 18 Oct 2024 |
Rating Of Existing Condensate Fractionator With New Heavy CondensateStarted by Guest_adnanaslam1988_* , 03 Feb 2024 |
Problem With Writing Offshore Plant Design BasisStarted by Guest_Doneisbetterthenperfect_* , 01 Dec 2023 |
