Dear Experts,
I am designing tank of size 77m Column supported fixed cone roof & observed that i have to refer Sect F.7 as per Fig:F-1.
Therefore for cal. of participating area i have to follow sect : F.5.1.My concern is :-
1 As per this formula : requires very high compression area.Which seems to be very unusual.Please suggest.
2 DLR : is the nominal weight of roof plate & attached framing.Now my question is since it is column supported therefore complete weight of roof plate & framing should not come as specified in API 650 sect : F.5.1 because columns will also share those weights.So only those weights which are actually coming on shell should be considered.Please give your idea for this matter.
3 Or no need to check participating area straight way provide Top curb angle say L150x10 greater than as specified in Sect : 5.10.6 .
4 If answer is no to question in S.No.3 then as per Fig F-1 what arrangement should be considered.
Approx. Weights are as follows just for your reference :
Shell 647 MT
Roof Plate 232 MT
Roof Structure Column Supported 350 MT
Platforms 23 MT
Please suggest,
Ashishpvnit
Participating Area Cal. For 18 Kpa Tanks As Per Api 650
Started by ashishpvnit, Apr 30 2012 05:26 AM
No replies to this topic
Posted 30 April 2012 - 05:26 AM
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Foam System Criteria For Hc Condensate Storage TanksStarted by Guest_Haideri_* , 28 Oct 2025 |
N2 Blanketing To Gasoline Tanks With IfrStarted by Guest_NICOLAST_* , 20 Dec 2024 |
Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
