Hello everyone,
I am looking for wisdom and suggestions on a process to remove chlorides from hydrofluoric acid.
We have an incinerator effluent that comprisses of a dilute aqueous hydrofluoric acid with some hydrochloric acid (1-5% by mass HCl/HF). Currently, the stream is neutralized and with lime, dewatered and landfilled. However, we would really like to be able to recapture our fluorine and reintroduce it to the process as potassium fluoride. We developed a similar process for another thermal oxidizer's effluent to make spray dryed potassium fluoride which is working well. However, in this case the chloride contamination is a quality concern and we can not simply neutralize and spray dry.
Does anyone have experience with or know of a process to economicly seperate aqueous solutions of HF and HCl?
Separation Of Aqueous Hcl From Hf?
Started by cischmidt, May 25 2012 09:44 AM
No replies to this topic
Posted 25 May 2012 - 09:44 AM
Separation Technology For Separate / Distillate Hcl From Water MixtureStarted by Guest_dpunnn_* , 11 Sep 2024 |
Air Separation Hysys ModelStarted by Guest_akkaset_* , 04 Jun 2024 |
Separation Of Ethyl Acetate And IpaStarted by Guest_Jaiganesh_* , 14 Apr 2024 |
![]() Different Separation TechnologiesStarted by Guest_hysyshunter_* , 27 Feb 2024 |
![]() Separation Of N-Butane From 1-Butene By Extractive DistillationStarted by Guest_Geetanjali_* , 21 Sep 2021 |
