Can members tell me where to get information on topic?
Pressure Effect On Freezing Point Of Water
Started by Azam, Nov 29 2005 05:10 PM
Posted 29 November 2005 - 05:10 PM
Posted 02 December 2005 - 08:08 AM
... on the Internet.
For example: http://www.princeton...ry.html#Skating
, http://www.newton.de...99/gen99523.htm and http://www.lsbu.ac.u...lan2.html#Pmelt as well as http://www.lsbu.ac.uk/water/phase.html
These links describe the relationship between pressure and melting/freezing temp as follows:
P= -395.2*((T/273.16)^9-1)
where T is absolute temperature in Kelvin and P is pressure in MPa.
This is valid for pressures up to 209.9 MPa. At higher pressures water freezes to ice-three, ice-five, ice-six or ice-seven at increasing temperatures.
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
