Slug Factor In Three Phase Horizontel Separator?
Started by Root, Jul 03 2012 08:12 AM
Posted 03 July 2012 - 08:12 AM
Can some one advice me for slug margin or factor how to include for separator sizing. Shell i can add in design margin or there is some procedure for this.
Toor
Toor
Posted 04 July 2012 - 03:35 PM
Toor,
One should know the size of the slug and its arrival rate to adequately size a separator that also functions as a slug catcher. Most of the commercial programs, like OLGA, can predict slugs reasonably well.
Good luck,
Good luck,
Posted 05 July 2012 - 02:44 AM
Toor
Analysis of the slug is necessary to arrive at the safety factor or over design margin to keep while designing 3-phase separators. I am sorry that I don't have such procedure to evaluate the slug and resultant effect on the separator performance.
Posted 08 July 2012 - 10:20 AM
Hi Padmarkar,
Thanks for your reply, I have got information from Shell DEP there is no need to add slug margin if this not a slug catcher.
Thanks again
Toor
Thanks again
Toor
Posted 10 July 2012 - 02:53 AM
Hi Toor,
If your separator is to treat a FLUID coming from a pipeline, potential of slugs always exists. Sometimes WELLHEAD production analysis shows less condensate production during initial years and increasing production during later years. In this case, the separator is designed for the highest capacity and the extra capacity available during initial years may also be reffed to SLUG VOLUME. Forget SHELL DEP or any other reference. These are not going to tell you whether slug will come or not. Its only you who can decide if slug volume is is to be incorporated or not. You can name the receiver vessel an inlet separator or slug catcher or whatever, but you have to incorporate slug into the design if it exists.
Haseeb Ali
Haseeb Ali
Edited by P.Engr, 10 July 2012 - 02:54 AM.
Posted 11 July 2012 - 05:28 AM
I am agree with what Haseeb Ali has written. You need the correct Interpretation of Shell DEP, i.e. phase separators which are designed to take care of slugs, should be designed as per guidelines applicable to slug catcher. You as a process engineer working on this system is the best person to judge/envisage such requirement and to take decision accordingly. If you anticipate that slugs, better to design the separator to cope with.
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
![]() Psv Flashing, Sizing Outlet Line 2-Phase.Started by Guest_felderosfelder101021_* , 09 Dec 2024 |
