I am confused with a unit conversion.
For 1Nm3 I have: 1.0571942 Sm3
1.0571428
1.0549129
Which one is correct?
Posted 21 July 2012 - 05:31 AM
Posted 21 July 2012 - 06:28 AM
tarfdar,
When you say Nm3 it is at 0°C (273.15 K) and 101.325 kPa (abs).
If you define Sm3 at standard conditions of 15°C (288.15 K) and 101.325 kPa (abs) then
1 Nm3 = 1.0549 Sm3 (288.15 / 273.15)
If you define Sm3 at standard conditions of 15.5556°C (288.706 K) also defined in english units as 60°F and 101.325 kPa (abs) then
1 Nm3 = 1.05695 Sm3 (288.706 / 273.15)
Companies like Shell define standard conditions as 15°C and 101.325 kPa (abs) for oil and gas operations everywhere in the world except North America. OPEC countries using english units follow standard conditions of 14.73 psia and 60°F. Have a look at the blog entry I had posted on standard conditions of temperature and pressure at:
http://www.cheresour...e-and-pressure/
Ankur.
Ankur.
![]() Flare Header Reverse FlowStarted by Guest_Ahmadhamzahperta_* , 04 Apr 2025 |
![]() Steam Flow And Heating Time In Batch ReactorStarted by Guest_seagal6_* , 16 Jul 2025 |
Aspen Hysys Simulation Of Acid Gas Removal UnitStarted by Guest_R.t_* , 22 May 2025 |
Heat Exchanger Steam FlowStarted by Guest_aliebrahem17_* , 25 Nov 2024 |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
