Calculation Of Cooling Tower Height
#1 kalpesh_iitm
kalpesh_iitm
  • 4 posts
Posted 21 July 2012 - 09:05 AM
I am 2nd year chemical engineering student..
I am doing project on a designing of cooling tower as a task
I have Following information:
1) wet bulb -dry bulb temp. 2) water in and out temp.
3) volumetric flow rate of circulating water
i have managed to calculate its losses (evaporation, windage, etc.) , flow rate of makeup water required and L/G ratio.
And as mentioned in Perry's Handbook I can calculate the tower characteristic value solving Merkle's equation by Simpson rule.
Now the problem is how can i calculate required height of cooling tower by using tower characteristic and L/G ratio or from nomograph.
I have to calculate required height for Natural Draft cross flow cooling tower...
I have gone through many pdf from internet for this project.
Please provide me required nomograph for given task..
Please Help me.
Thank You..
Kalpesh
  • 6,724 posts
Posted 21 July 2012 - 06:47 PM
Hi.
Consider these documents to support your query .
Additional info are available in Perry's chemical handbook.
Hope it helps.
