hay
i have to design a fired heater to heat carbon mono oxide from 402 k to 1223 k while its autoignition temperature is 903 k ???? what should i do?????
how we select the diameter of tube in fired heater!???????tube selection criteria?????
Fired Heater Design
Started by bravemaster, Aug 03 2012 12:04 PM
heat transfer.furnace fired heater fired heater design carbon mono oxide heating
Posted 03 August 2012 - 12:04 PM
Posted 04 August 2012 - 02:07 AM
bravemaster,
Two references:
http://www.heaterdes...com/design0.htm
API STD 560, 4th Edition - Fired Heaters for General Refinery Service
Two references:
Posted 04 August 2012 - 04:54 AM
bravemaster,
Provide a complete data sheet for required fired heater package as per API 560 and leave the design to a reputed vendor.
Fallah
Fallah
Posted 04 August 2012 - 12:25 PM
TRy PGThermal technologies site; winheat demo pgm;HTRI example pgms.
Posted 05 August 2012 - 05:43 AM
Fired heater design is available: Process engineer's hand book by atinheWallace.
Winheat and HTRI are the softwares.
PGtherma.l site gives on line calc software
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
