Aspen Tech User Defined Component
aspen userdefined component property database
#1 mpchemical
mpchemical
  • 3 posts
Posted 12 August 2012 - 04:23 AM
Dear All:
I was searching for how to add user defined component in Aspen V7, but failing to understand the methodology. I was trying to put 2 4 Dichlorophenol, 2 6 Dichlorophenol, 2 4 6 Trichlorophenol in aspen to design the separation train. I tried my best but unable to converge.
I have not used Aspen before for the components which are absent in aspen. Please help.
Thank you
#2 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 12 August 2012 - 05:29 AM
Can you please post the hysys file to have a look?
Ajay
#3 mpchemical
mpchemical
  • 3 posts
Posted 13 August 2012 - 09:36 AM
Which file you are talking about? I am unable to put extended Antoine vapor pressure coefficients in the given format.
#4 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 13 August 2012 - 11:17 PM
I was refering to the file, which could not be converged. I'm assuming you are using aspen hysys.
Ajay
#5 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 14 August 2012 - 02:06 AM
I could find all the 3 compounds in hysys. Please make sure your system has "Aspen properties" installed. Click on "Aspen Properties Databanks" then "Add" components using "Launch Find Component Window". The hysys file having these 3 phenols are attached as rar file.
Please let me know if I understood your question correctly.
Ajay
#6 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 14 August 2012 - 02:09 AM
It seems I cannot upload .rar or .hsc files.
#7 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 14 August 2012 - 02:10 AM
.zip file worked.
