hi
I'm a student investigating the various methods to apply glass coatings on the outside of bare metal tubes (majorly carbon steel) to prevent corrosion due to sulfuric acid condensation. The thickness i'm looking forward to is about a few hundred microns.
I would like to know what all methods can be used to coat the tubes with glass for this thickness, their cost effectiveness, and also if there are any good alternatives to the methodology i'm trying to pursue.
Thank you in advance
Kushal
Glass Coating Methods
Started by Kushal, Aug 22 2012 05:35 AM
Posted 22 August 2012 - 05:35 AM
Posted 30 August 2012 - 02:31 AM
Hello Kushal,
I'm by no means an expert, just putting in my two cents.
A few years ago I did a project regarding OLEDs where we needed to achieve a layer of ITO (Indium Tin Oxide) on a layer of glass, the process is quite similar for what you could use;
http://en.wikipedia....apor_deposition
Also a similar process is : http://en.wikipedia....apor_deposition
Which is used to apply gold coatings to materials which are not conductive, for use with SEM.
Problem is that you need a vacuum enviroment to ensure the substrate on your product is the desired one.
http://www.francoisc...li_Tantalum.pdf Perhaps also some interesting reading, electroplating the tubes.
Edited by Wit Knien, 30 August 2012 - 02:44 AM.
Posted 30 August 2012 - 04:41 AM
Glass Lined Tubes and Heat exchanger are available. Also pure Borosilicate glass Shell and tube heat exchanger are also available. Both can be used for Sulfuric Acid Condensation.
Please visit
www.thaletec.com
www.ablazeglassworks.com
Hope this shall help you
SRShah
Please visit
www.thaletec.com
SRShah
How To Use 2 Different Property Methods In The Same Aspen Plus SimulatStarted by Guest_MattLochner_* , 23 Sep 2024 |
Glass Line Reactor CoolingStarted by Guest_imdhanya17_* , 31 Jan 2023 |
521 Fire Alternate MethodsStarted by Guest_therossboss_* , 19 Apr 2022 |
Definition Of Critical Electrical Loads And Methods To Handle ThemStarted by Guest_Vegeta_* , 14 Aug 2022 |
Friction Drop MethodsStarted by Guest_Unnatiyr_* , 24 May 2022 |
