Fire Case Of Venting As Per Api-2000
Posted 23 August 2012 - 05:59 AM
Please find attached an Excel Sheet wherein I have tried to calculate the Venting capacity of Pressure Safety Valve for Double wall double integrity Ammonia Storage Tank. I tried to calculate the capacity of Venting as per API-2000 for the case when there is fire around the Tank. Calculation have been done for FPS and SI unit system. However, both the answer are different. I am not able to spot the error in my calculation. I am also not sure whether my calculation is correct. Please guide me in correcting the Excel sheet.
Alok
Posted 23 August 2012 - 06:01 AM
Alok
Posted 02 December 2012 - 01:20 PM
Dear all,
Alok
Dear Alok,
I do think the mistake is due to the units of vaporization heat in SI (cell I12 of your spreadsheet). Vaporization heat in the API 2000 formula is in J/kg, not in kJ/kg. You have to multiply by 1000 the vaporization heat value.
Cheers
Stefano
Posted 05 December 2012 - 02:17 AM
1. British Unit
W = 64431391 x 0.05 / 587.826 =5480.5 lb/h or 2485.5 kg/h
2. SI Unit
W =(18882626/1000) x 3600 x 0.05 / 1367.283 = 2485.85 kg/h
3. Even-though not exactly the same but very close
4. Pls take note that your equation for NM3 conversion is incorrect.
Edited by S.AHMAD, 05 December 2012 - 02:24 AM.
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Fire Case Psv For Lean Glycol FilterStarted by Guest_Arsalan_1992_* , 08 Nov 2025 |
Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
