Acid Gases Flammability
#1 vista
vista
  • 28 posts
Posted 24 August 2012 - 01:55 AM
are the acid gases (H2S and CO2) are flammable? what is the proper disposal method of these gases?
  • 6,988 posts
Posted 24 August 2012 - 03:18 AM
Vitsa
Take a look at the MSDS (material safety data sheet) ! you should get your answer .
http://www.airgas.co.../pdf/001029.pdf
Don't you know that CO2 is used in some extinguishers ?
Hope this helps.
Edited by breizh, 24 August 2012 - 05:49 AM.
#3 vista
vista
  • 28 posts
Posted 24 August 2012 - 08:51 AM
Yeah i do know that CO2 is used to extinguish the fire, I was confused about its mixture with H2S...we remove about 400 ppm H2S and 1.8 mol % of CO2...both of them goes to flare where we also add some sweet gas for ignition...my querry is about this whole mixture of acid gases...what will be the result if we do not add sweet gas?acid gases will be burned or not?although H2S is a flammable ....
#4 Art Montemayor
Posted 25 August 2012 - 09:31 AM
Vista:
As Breizh has indicated, CO2 is a well-known inert gas. It’s presence in your flare gas diminishes the flammability of the mixture. Instead of making “real-time” calculations on the flare gas to find out if it will burn on its own, what the flare designer and manufacturer has to do is to design for the eventual incineration of such gas mixtures.
That is why fuel gas (what you call “sweet” gas) has to fed to the flare and burned there. This fuel gas serves as the heat source for decomposing the flammable constituents in the flare gas. The H2S should be oxidized to SO3 if the combustion is complete. This is elementary chemistry. The CO2 and nitrogen (in the combustion air) as well as excess oxygen will all be products of the combustion as well.
Your flare installation should have detailed engineering files and calculations – as well as an operating manual. You should have detailed calculations on the expected combustion that is to take place in the flare. Consult with that documentation. If it doesn’t exist, it should be generated and kept in the engineering files.
