Error Ms Excel And Aspen Plus Interface
Started by mydarkoline, Aug 31 2012 02:02 PM
aspen plus ms excel error message in aspen simul
Posted 31 August 2012 - 02:02 PM
I am trying to do the modelling of the pervaporation system with MS Excel and then link it to Aspen plus using a template provided by Aspen Plus. I get this error message:
*WARNING IN PHYSICAL PROPERTY SYSTEM
NRTL BINARY PARAMETERS FOR ALL COMPONENT PAIRS ARE ZERO,
YOUR RESULTS MAY NOT BE ACCURATE. PLEASE REVIEW AND PROVIDE BINARY
PARAMETERS AS APPROPRIATE.
Block: MEMBRANE Model: USER2
*** SEVERE ERROR
MS EXCEL Interface Reports:
TableData Wrapper
VBTableData object is not created
* WARNING
TOTAL FLOW IS ZERO
* WARNING
TOTAL FLOW IS ZERO
* WARNING
BLOCK MEMBRANE IS NOT IN MASS BALANCE:
MASS INLET FLOW = 0.48311503E+01, MASS OUTLET FLOW = 0.00000000E+00
ABSOLUTE DIFFERENCE = 0.48311503E+01
CHECK USER SUBROUTINE
Does anyone have ideas as to how to fix this problem? I have tried everything I know in Aspen plus but it is not working. Thanks.
Posted 19 February 2013 - 10:55 PM
I came across the same problem as you when following the instruction of Aspen to simulate a ultrafiltration membrane.
Could someone help us out?
Posted 19 February 2013 - 11:25 PM
is it possible to post it here? Would help to actually look at it. Who knows, it might turn out to be a software bug!
Posted 03 July 2013 - 10:32 AM
Have anyone found a solution for this error?
Petrosim Python InterfaceStarted by Guest_tomr91_* , 28 Apr 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
