Pump As Turbine
#1 nazar
nazar
Posted 03 September 2012 - 07:06 PM
i have a question here.. Can be pump as turbine work at the same time rotate as the turbine then pumping water to the other level of height??
Posted 03 September 2012 - 08:37 PM
Nazar:
Your English is very hard to understand; but if you are asking if a centrifugal pump can be made to operate in reverse - acting as a turbine and generating work - the answer is definitely YES.
I have run some exactly in that manner. In fact, as far back as 50 years ago, I remember that the duPont corporation used to operate some pumps that way also - in their West Virginia Plant, if I'm not mistaken.
#3 breizh
  • 6,979 posts
Posted 03 September 2012 - 09:25 PM
Consider Google to support your query , you will find additional info :
http://www.google.co...iw=1129&bih=623
