I found some interesting topics about supercritical PSV in this forum; however, I can not reply so I want to start a new one and raise my concerns. Hope someone could help me to sort them out.
"Rigorously size relief valves for supercritical fluids by Ryan Ouderkirk" provided a better sizing method instead of the reluctantly using equation 8, 9 and 12, section 5.15.2.2 of API 521 which are based on the phycal properties of air and perfect gas law. Article comes with an example for single component (n-butane). If we spread this out. In case vessel contains oil (multi-component, different boiling range), dense phase will apprear if fluid is heated to supercritical condition. Dense phase could be a homogeneous mixture. Question:
1. With assumption that fire occurs during long term, this leads to temperature increase step by step although fluid is relieved by PSV to maintain vessel pressure. Is that reasonable if we consider molecular weight of fluid inside vessle is constant value?
2. Article present equation to calculate the isentropic-nozzle mass flux: G = (2*(H0 - Hb)^0.5 / Vb x 3955.77 (reference 21). Could anyone tell me the basic of this equation? where does it come from? and how to consolidate/prove mathematically.
Thanks,
Eastorca
