Can we prevent this deposited from happing again? "we checked H2S in fuel gas , it's less than 10 ppm"
You said sulfur deposit. Formation of elemental Sulfur reacts at very high temperature (>800°C if I'm not mistaken) so the offgas streams must have come from a process similar to SRU or TGTU (as with my last post).
Or is it really sulfur? Have you had it qualitatively checked? Is it possible that it may be ammonium salts (from NH3)?
Is the boiler very sensitive "in case of fuel gas composition changed???"
That depends whether if you rely on offgases as your primary source of fuel. My thinking is normally boilers use fuel gas as primary source of fuel and this is just supplemented by offgas from various refinery units.
That may or may not be the case in your system, but anyhow it's the HV (heating value) that matters in boiler operation. Changes in composition may affect the heating value of your fuel gas. By how much? That I can't answer.
What is the general practice that’s followed worldwide to deal with flashed gas?
General practice is you normally treat the flashed gas with amine to scrub the sour gases that may cause emission problems in your boiler.
In your case, without any idea on how your plant works, my guess is as good as anyone's here in the forum.
If you were in my place what you will doJ?
I'll check for ammonia content of your offgas. That's just me though
Good luck!
