I have given more details in screenshots in the attachment, but essentially I have been handed over a HYSYS simulation of a High Pressure steam reboiler embedded in a Heat Recovery and Steam Generation unit.
The exchanger shows a temperature cross and I would like some input on how to relieve this constraint.
I asked my line manager and I have been told not to worry about it because, and I quote, "It is indeed true that the exchanger seems to have temperature cross but there would be no temperature cross in a real operation. As you know, it is not recommended to design a heat exchanger where it has two phase flow in either tube or shell side (if it is not a kettle-type reboiler) because in general a two-phase flow has relatively lower heat transfer coefficient than a liquid flow and also it is not easy to control the process when phase change occurs inside the heat exchanger. Therefore, in the design of evaporator of the steam cycle, it is usual to avoid generating steam inside the heat exchanger. The actual evaporation takes place in a drum which is located on the top of heat exchangers due to static head. The hot water is heated inside the heat exchanger at a higher pressure than a desired pressure and then slightly depressurised in a drum for its evaporation."
I am not entirely convinced the analysis above is correct. Any opinions from experienced designers of this type of units?
Thank you in advance.
Ennio (Enal)
