3 Element Level Control In Boiler
Started by daure.tejaswini, Sep 25 2012 06:12 AM
3 element control boiler boiler level control level control
Posted 25 September 2012 - 06:12 AM
In boiler 3 element control, why we take feedwater flow rate in cascade with drum level and steam flow rate in feedforward control?
How connection for lead-lad realy is done to avoid shink and swell?
According to my knowledge, inlet flow rate is taken in feedforward and outlet flow rate in feedback to control level in tank. Can some please explain why this is not followed in boiler
Posted 25 September 2012 - 07:09 PM
Daure,
The function of the loop is to maintain the drum level. Since most drums are small in comparison to holdup, the steam flow is a feedforward measurement to modulate BFW flow without waiting for a level change. It's that simple.
Posted 26 September 2012 - 01:24 AM
Thank you Bobby.That will be like material balance. Will you please tell me significance of level measurement?
Edited by daure.tejaswini, 26 September 2012 - 02:43 AM.
Posted 26 September 2012 - 08:33 AM
Daure,
For steam drum level control, the modern 3-element system steam flow, feedwater flow and drum level should be selected. Steam and feedwater flows are compared, with feedwater being requested accordingly and trimmed by the drum level signal. This system is better than having the drum level directly control feedwater, because foaming or changing steam drum conditions can cause a misleading level indication. Also, the 3-element controller responds faster to changes in demand.
Posted 26 September 2012 - 11:10 AM
Daure,
It's the level that you want to control. The three-element control accomplishes this most reliably.
![]() Level Control ValveStarted by Guest_Ilyes_* , Today, 02:55 AM |
Surge Analysis-Control LogicsStarted by Guest_stu_* , 30 Dec 2024 |
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
![]() Pump Dischrge Control Valve SizingStarted by Guest_Lyne_* , 04 Jun 2024 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
