Gas Blow By Calculation
Started by renin, Oct 02 2012 07:14 AM
10 replies to this topic
Posted 02 October 2012 - 07:14 AM
how can i size a psv for gas blowby scenario?i need the formula that can be used to get the mass flow through the control valve in an open state for critical and sub critical flow?
Posted 02 October 2012 - 07:33 AM
renin,
The gas blowby scenario isn't so simple that it can be compressed in one formula by which you can obtain the relevant relief load for PSV sizing!
Try to use some basic references such as API 521 to get my above idea and then in the way you will be trying to obtain the relief load, submit your questions in order to get members assistances.
Fallah
Fallah
Posted 02 October 2012 - 07:49 AM
hi renin
as Fallah says you need to read and understand
API 521 para 5.10 Failure of process stream automatic controls
this should help you progress to teh next stage
flare e nuf
flare e nuf
Posted 02 October 2012 - 05:02 PM
And you must consider that the bypass valve might be open, too.
Posted 03 October 2012 - 01:15 AM
so how can i get the relief load for gas blowby from the control val formula?i would like to know the control valve formula to use in getting the relief load which can then be used for the sizing
Posted 03 October 2012 - 01:30 AM
renin,
Try to get Fisher control valve handbook.
Fallah
Fallah
Posted 03 October 2012 - 06:34 AM
can i get a worked example on gasblowby psv sizing so that i can have a good understanding of this scenario?An excel spreadsheet will be much appreciated. Thank you.
Posted 03 October 2012 - 06:57 AM
renin,
IMO,understanding a concept, let say analysing a gas blowby case in order to obtain relevant relief load, by using just a worked example is not a right way of learning. In gas blowby scenarios each case has its own characteristics and hardly depends on the conditions of upstream/downstream equipment and the process conditions of the whole system in which the control valve, as the main point of such scenario, is included.
As previously mentioned start to learn from basic references and then in this way (and after that in applying the learned skill on an example) if you would need any help we are ready to do.
Fallah
Fallah
Edited by fallah, 03 October 2012 - 06:58 AM.
Posted 03 October 2012 - 07:12 AM
thanks a lot for your kind response.i have studied the handbook talked about and i am well aware of the relief load that can be used in getting the size for the Psv. but i believe that one still needs a real life example on gas blowby scenario to really grab the concept and put all that is learned into test. your response would be much appreciated.thank you
#10
Posted 03 October 2012 - 07:19 AM
renin,
Thanks for your understanding. Now you can submit your specific query on a real example to get the needed help.
Fallah
Fallah
#11
Posted 03 October 2012 - 07:37 AM
a spreadsheet on gas blowby sizing would be good.
Effect Of Continuous Blow Down To Boiler Feed WaterStarted by Guest_Dyames027_* , 21 Nov 2024 |
Hcl Fumes CalculationStarted by Guest_Chemeng40_* , 16 Oct 2024 |
Hydraulic CalculationStarted by Guest_applepe_* , 06 Oct 2024 |
![]() Final Composition Calculation Of First Iteration Of Methane Steam RefoStarted by Guest_kikisapsal_* , 14 Sep 2024 |
