Fusel Oil
Posted 10 January 2006 - 05:31 AM
The fusel oul contains mainly Amyl Alcohol (70-75%) and balance higher alcohols.
Can somebody help in separating amyl alcohol from the fusel oil. The qty of fusel oil is approximately 1000 kg/hr.
Thanks in advance.
Posted 13 January 2006 - 04:12 AM
I thought you would be able to atleast give me some clue about the subject. I am still waiting for a reply...
Warm regards and thanks in advance
Samir
Guest_flavoryou_*
Posted 12 April 2006 - 07:41 AM
Samir
Depending on your distillation equipment, you should be able to fraction out the Amyl alcohol through a refinement in how you process your distillate. In order to fraction out the Amyl (2-Methel-1-Butanol) from the Isoamyl, propanol and other fusels, you need to have many plates (40 plus) with the ability to draw off fractions at each specific plates. If you do not have this ability, try and separate the fractions by controlling the output alcohol percentage to best match the boiling points of your desired fractions. Use this study to help dial in what your median temp. and subsequent alcohol percentage draw off of the back end is to achieve your desired lower Amyl levels. IE. you might have to draw off a little slower or run your condensor a little more to help fraction in the column. Just copy and paste this link below. The data in Table 1 and 2 should be of some help for this.
http://www.chemeng.t...aper/active.doc
Posted 12 March 2007 - 02:27 AM
Posted 30 March 2010 - 09:18 PM
I am also looking for Extractive separation methods for separating Amyl alcohol from fusel oil.
Hello
I'm simulating a tower to fracture out Ethanol (93.8%mass) on top, Fusel in the middle tower from mash luiquid with 45.316%Alcohol. But I don't have a typical composition of Fusel.
Could you help me, please?
Posted 01 April 2010 - 12:28 AM
Fusel oil is poduced as a by product in cane molasses based fermentation plant and subsequent recovery of Rectified Spirit or Industrial Alcohol through distillation.
Thanks in advance.
Samir,
If you can give some more information on the content of feed and product specification. We can do a simulation and give some suggestion to you. Our company is doing the process simulation and seperation equipment design. Please send these data to my email Johnhuang@zehua-chem.com
You can visit our website www.zehua-chem.com
John
Fusel OilStarted by Guest_isjabu_* , 29 Jun 2021 |
Fusel OilStarted by Guest_l369q_* , 17 Feb 2013 |
FuselStarted by Guest_haih5_* , 30 Mar 2010 |
Rectified Column To Distillate Ethoh & Fusel From WaterStarted by Guest_haih5_* , 25 Mar 2010 |
