I am working on simulation for Vacuum Column please tell me the books which can be useful for me for that project
If some One has this book please share it
" Process design for reliable operations Norman p. Lieberman "
Posted 17 October 2012 - 07:55 AM
Posted 17 October 2012 - 08:08 AM
I think you should try to get the book you specify from your college library. It is not legal to "share" digital copies of the book without paying its part to the author.
The Henry Kister's book was really helpful for me, maybe you can find it in the library or, if you can buy it, here's the link:
http://www.amazon.co...r/dp/0070349096
The same author also have a book dedicated to operations.
Posted 17 October 2012 - 11:43 PM
Thank you
![]() Time Required To Heat Up A Fluid In A VesselStarted by Guest_panoska_* , 24 Jan 2023 |
I Made An App That Resembles The Process Engineer Pocket Book By CarlStarted by Guest_ahmedhassan676_* , 25 Jan 2024 |
Heat Required For Boiling Liquid MixturesStarted by Guest_halkeshhulk_* , 07 Oct 2023 |
Suggestion For Reference Book For Process Plant CommissioningStarted by Guest_JKM_* , 17 Feb 2023 |
