Hi all,
Could you please suggest the advantages and disadvantages Slip stream MEG Regeneration & Reclamation process over Full Stream process and process selection criterion for those two process.
Thanks & Regards,
Sriniiiii
Meg Regeneration And Reclamation
Started by cnu879, Oct 20 2012 01:25 AM
Posted 20 October 2012 - 01:25 AM
Posted 20 October 2012 - 10:03 AM
You regenerate the whole stream for water removal. Contaminant level will determine how much reclaiming is needed. Best to talk to process technology and equipment suppliers if you need to buy a system.
Posted 20 October 2012 - 07:40 PM
Full Stream Concept
Removes all the salts to prevent scaling in the pipelines
Slip Stream Concept
Removes the necessary salts to prevent scaling in the pipelines
Full stream reclamation
■ The entire feed is vaporized –
Reconcentration and reclamation in one operation
Slip stream reclamation
■ Conventional reconcentration (water removal) process at
atmospheric pressure – Saves energy costs and eases operation
■ The reclaimer operation (high solubility salts removal) is
performed on a slip stream of the regenerated MEG
■ High availability – Reclaimer only required during formation water
production otherwise bypassed
■ Reuse of chemicals (corrosion inhibitor / pH stabilizer)
Slip Stream Concept
- Slip Stream more suited for units with periods with no/low formation water production
- Slip Stream allows larger reconcentration trains, thus suited for bigger capacities
- Typically, Slip Stream is smaller in size
- Slip Stream needs more advanced Pre-treatment (to remove the low soluble salts)
- Reduced Criticality of Reclaimer
Posted 22 October 2012 - 01:24 AM
Thanks Dhiren and Bobby for your reply.
Full Stream MEG regeneration and reclamation process removing all the soluble salts by fully reclaiming the MEG. All solids, dissolved salts and chemicals are removed by vaccum evaporation of Water + MEG.
Please suggest favourable vaccum conditions (Pressure & Temparature) for Flash Separator and Regeneration Distillation Column and associated equipments.
Please find the attached Full Stream MEG Regeneration Process schematic sketch.
Sriniii
Sriniii
Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
Triethylene Glycol (Teg) Regeneration SystemStarted by Guest_guoyinyanliner_* , 23 Jul 2025 |
Molecular Sieve Regeneration At High PressureStarted by Guest_Victor_process_Engineer_* , 07 Jan 2025 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
Zeolite Bed RegenerationStarted by Guest_TestTest_UK_* , 28 Jan 2024 |
