Hello
I have designed a standard kettle reboiler, but i don't know how to calculate the static head. When can we design trapout kettle? what is difference between static head calculation of these two type kettle reboilers and their head static?
In addition, I have designed six internal reboilers for the vacuum condition. Please help me about design guidelines, for example the position of the reboiler in the sump of a column.
Thanks in advance
Kettle And Internal Reboiler
Started by Guest_minoo81_*, Oct 22 2012 07:00 AM
kettle and internal reboiler
Guest_minoo81_*
Posted 22 October 2012 - 07:00 AM
Posted 23 October 2012 - 03:32 AM
What do you mean exactly with "static head"?...
My guess is that you have a column and you're trying to calculate the pressure that the column bottoms will have when they reach the reboiler, is it correct?
In this case, you should have some data about the height of the liquid in the column bottom considering internal baffles, as well as the liquid density and the pressure inside the column.
Posted 23 October 2012 - 06:58 PM
Minoo81,
this resource may support your query .
Hope this helps
Hope this helps
Posted 24 October 2012 - 02:19 PM
There are two parts to the static head in a kettle reboiler. The first part is between the inlet of the reboiler and the boiling surface. The density used is for a two phase mixture.The second part is from the boiling surface, through the return line and back down to the liquid surface in the tower. The density used is the outlet vapor density.
Posted 25 October 2012 - 10:54 PM
Minoo81,
additional input to support the query.
Phe As ReboilerStarted by Guest_Chemeng40_* , 20 Feb 2025 |
![]() How To Replace Existing Reboiler With A Thermosyphon Reboiler In HysysStarted by Guest_tomr91_* , 04 Feb 2025 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
Pumpback Reflux/ Internal RefluxStarted by Guest_Venkat @89_* , 26 Sep 2024 |
