Can any one tell me the purpose loading dry crude oil from the top using inclined inlet distributor in crude oil storage tank.
Is this meant for easy degassing ?????
Crude Oil Inlet To Storage Tank
Started by Satheshchem, Oct 22 2012 01:45 PM
Posted 22 October 2012 - 01:45 PM
Posted 22 October 2012 - 04:28 PM
Yes. Or sometimes a degassing boot is used before entry into the tank.
Posted 22 October 2012 - 10:40 PM
Thanks for the reply, but why inclined inlet distributor? Why not normal horizontal inlet distributor.is there any velocity criterion to size nozzle???
Can you explore it bit if you have vast idea on this ??
Crude Assay Pure Component AdditionStarted by Guest_darknight1991_* , 17 Jan 2026 |
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
