Hello All,
I was wondering if a bleed ring symbol should be shown on a P&ID drawing for PSV's?
Thanks,
Kybele
Posted 24 October 2012 - 09:31 AM
Posted 25 October 2012 - 12:15 AM
kybele,
What do you mean by "bleed ring"?
Fallah
Fallah
Posted 25 October 2012 - 08:08 AM
Fallah,
Some companies requests a bleed ring which is a kind of flange with a tab on it and instead of using double block and bleed valve system they use this ring and it is connected to a valve to bleed the downstream or upstream line before maintain PSVs. This is my understanding from bleed ring. I belive it should be shown on P&ID's because it substitute the B&B valve system.
Thanks,
Kybele
Thanks,
Kybele
High Vibration Liquid Ring CompressorStarted by Guest_Aziz846_* , 07 May 2023 |
Can You Recycle Edi Electrode Flush And Concentrate Bleed?Started by Guest_J_Leo_* , 14 Feb 2022 |
Double Block & Bleed Valve For Acid Gas LineStarted by Guest_gr8azhar_* , 03 Jun 2019 |
Liquid Ring Vacuum Pump Seal LiquorStarted by Guest_TheChemEng_* , 16 Jan 2019 |
Requirement For Bleed At Psv OutletStarted by Guest_SawsanAli311_* , 04 Dec 2018 |
