Dears:
Please tell me your experience whether the plunger pump can used in gas sweetening plant for amine circulating ?
thanks alot
m.r.rahimzadeh
Plunger Pump
Started by Rahimzadeh, Oct 24 2012 10:44 PM
Posted 24 October 2012 - 10:44 PM
Posted 25 October 2012 - 04:45 AM
Why do you suspect that it cannot be used?
Posted 25 October 2012 - 01:09 PM
m.r.rahimzadeh:
Of course a plunger pump can be used for circulating amine solution in a gas sweetening process - especially if the amine absorber is operating at relatively high pressures.
However, since the maximum capacities for such pumps are relatively small as compared to centrifugal units, you will find that such pumps have difficulty meeting the capacity specifications for most industrial-sized gas sweetening operations.
Posted 01 November 2012 - 12:37 AM
I've been forced to use reciprocating pumps only in the smallest amine unit I've designed.
In that case the amine circulation was around 1.5 t/h.
The unit has been built-up but not yet started-up.
Vacuum PumpStarted by Guest_R.t_* , 19 Sep 2025 |
