Posted 07 November 2012 - 11:55 PM
How do you thnk shut off head affects the pump discharge head.
Lets say I have a pump with inlet head of 2 m and a differential head of 3 m.My shut off head is 4 m. What discharge head will I get? 5 m or 4 m
Thanks in advance
Gyan
Posted 08 November 2012 - 12:34 AM
H = f (Qv) .
Shut off means no flow !
Hs = 2m ; Hd-Hs = 3 m>>> Hd = 5m
Posted 08 November 2012 - 01:34 AM
Edited by gkumar, 08 November 2012 - 01:40 AM.
Posted 08 November 2012 - 01:46 AM
The operating point is at the intersection of the pump curve and the system curve .
Posted 08 November 2012 - 04:31 AM
Lets sat I have inlet suction head of 1.5 m and a differential head of 2 m. I will get an out put of (2+1.5) 3.5m. Now if the pump's shut off head is 3.8m and I increase the suction head to 2.5 m, will I get a discharge output of 4.5 m or it will not go above the shut off head?
Posted 08 November 2012 - 11:42 AM
Shut off head is differential head at pump shut off and with a suction head of 2.5 m and shut off head of 2 m you will get 4.5 m head as pump discharge head at shut off condition.
Fallah
Posted 08 November 2012 - 07:51 PM
Posted 08 November 2012 - 08:27 PM
Posted 08 November 2012 - 11:18 PM
gkumar,
Fallah
Hi Fallah
Thanks for the reply!
I believe in place of "shut off head" (colored portion) you meant "differential head". Isn't it? Can my suction head go above my shut off head? Yes or No.
#10
Posted 09 November 2012 - 12:33 AM
First of all, you have a pump with a known performance (aka characteristic curve). From this, you can get the differential head for a given flowrate.
Shutoff head, as implied by the word itself, means head at no flow.
For a given impeller and a given pump (and fixed RPM), this head is unique.
You have to realize that the pump curve is flow vs differential head (discharge - suction head). You can't get the discharge head by looking at the curve alone. You also need to know the suction head and add the corresponding differential head to obtain the discharge head.
So basically, suction head and differential head are not comparable with its other (former is a function of system configuration such as elevation, pipe length etc while the latter is a function of the pump performance itself). So yes, suction head can be higher than shutoff head (as defined in this post as the differential head at no flow) by making the source vessel high enough, but it won't make any sense to compare the two because one is an absolute term and the other one is a difference term.
But if by "shutoff head" you mean the actual head produced by the pump at zero flow (which means suction head + differential head at zero flow), then no, it's not possible that shutoff head < suction head.
In this case you have suction head of 1.5m and a differential head (at the same flow) at 2m, so your discharge head is 3.5m (as you correctly state).Thanks Breizh
This is where all the confusion arise.Now if the pump's shut off head is 3.8m and I increase the suction head to 2.5 m, will I get a discharge output of 4.5 m or it will not go above the shut off head?
By fixing the 3.8m shutoff head even though you have an increase in suction head implies that this value is in fact the differential shutoff head.
In this case, if you increase the suction head to 2.5m (by elevating the vessel or increasing the source vessel pressure), the corresponding discharge head would be 2.5m + 2m = 4.5m.
Looks like we exceeded our shutoff head!
NOT!
Because (as I already said) the shutoff head (3.8m) is differential head, so to get the absolute shutoff head, you have to add 3.8m to the suction head at NO flow (which is NOT equal to 2.5m since this corresponds to a particular flow which is not zero).
At any rate, you just increased your shutoff (absolute) head by increasing the suction head, but the shutoff (differential) head will remain the same unless you increase the pump RPM, impeller diameter or replacing the pump altogether.
TL;DR version: No, discharge (or suction for that matter) head will NEVER exceed shutoff (absolute) head.
Edited by Dacs, 09 November 2012 - 12:43 AM.
#11
Posted 09 November 2012 - 07:44 AM
gkumar,
Yes, the suction head can go above pump's shut off head.
Fallah
#12
Posted 09 November 2012 - 01:32 PM
Clarifications on pump "heads" can be seen in Perry, Transport and storage of liquids / Pumping of liquids and gases / Introduction (page 10-22 in 7th edition).
Suppose in your example (post 5) that shut off pressure =3.8 m L g, when suction pressure is 1.5 m L g and discharge pressure is 1.5+2.0=3.5 m L g at normal flow.
When suction pressure =2.5 m L g , shutoff pressure will be 4.8 m L g, since shutoff (differential) head remains constant at 2.3 m L
(in above 2.5 m L g means 2.5 m of liquid column above atmospheric pressure; 2.0 m L may be too small for pump diff pressure, but does not mind the example).
In pump data sheets here, we specify suction, discharge, shutoff pressures in gauge pressure units (e.g. Barg) for clarity; "head" is only used for pump head (expressed in m of liquid), corresponding to pump differential pressure.
Edited by kkala, 09 November 2012 - 01:42 PM.
Understanding Polytropic Head And Its Relationship With Gas DensityStarted by Guest_Kakka_* , 18 Dec 2024 |
Discharge Head Or Differential Head, Pump CurveStarted by Guest_panoska_* , 11 Nov 2024 |
Centrifugal Compressors (Actual Vs Polytropic Head)Started by Guest_panoska_* , 25 Oct 2024 |
Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
Doubt In The Represntation Of The Pid Controllers In P&id DiagramStarted by Guest_myself_ritesh_* , 24 Jun 2024 |
