Hello
I am in the middle of my final project at university, and I need to send hydrogen gas for storage at 250 bar.
I am thinking about a multi stage compressor with heat exchangers between them, but I can´t find a good compression rate with a reasonable temperature discharge.
My system consists of 340 kg/h.
Can someone please tell me untill what temperature I can handle the hydrogen gas, ou some examples of this compression system?
Thank you.
Posted 23 November 2012 - 07:55 AM
Posted 23 November 2012 - 09:54 AM
For such a service with very low flow rates and high compression ratio, multi-stage reciprocating compressors would be the most suitable. Since it is hydrogen service the compression ratio per stage should be maintained such that the discharge temperature per stage does not exceed 135 deg C (API 618 guidelines for hydrogen rich service). The gas from each stage shall be cooled using inter-stage coolers before it enters the next stage.
Posted 23 November 2012 - 11:28 AM
Diaphram compressors are typically used for this service.
Posted 23 November 2012 - 12:24 PM
Vineguimaraes:
You are proposing to compress hydrogen from an unstated suction pressure (?) and temperature (?) to a discharge condition of 250 bar(?) and an unstated temperature (?). Please don’t mess up your future engineering career by failing to state what the values of the (?s) are. I am not reprimanding you; I simply want to help you establish yourself as a successful future engineer. You MUST communicate all the required, necessary basic data necessary to respond to a query in a concise and accurate manner. This is a basic requirement in engineering and will be imposed on you as you further your career. This is the most important item I can help you on. I can also give you factual and experienced advice on how your procedure is carried out in industry since I have done it many times before. This part of my response is not as important as the first one:
If you require additional, specific information and details, please state them.
- Since you don’t furnish accurate and complete basic data, I have to make several assumptions. Your suction conditions are atmospheric pressure (14.696 psia) and 60 oF. Your discharge conditions are 250 bara (3,625.94 psia) and 30 oF (86 oF).
- The flow rate of the compressed hydrogen is 340 kg/h = 1,496 lb mol/h = 567,717 Scfh = 9,462 Scfm (measured at 60 oF & 14.686 psia). This is NOT A SMALL volumetric flow rate and the type of service is quite conventional (in the USA), using 4 to 5 stage reciprocating compressors. You would require several, relatively large machines.
- I have discussed this specific subject several times in past threads within our Forums and you can access the information – complete with schematic diagrams and flow sheets – detailing how the operation is carried out and controlled.
Cosi2 And HydrogenStarted by Guest_Xanthophyll_* , 17 Oct 2024 |
![]() Hydrogen Storage Tank Depressurization Duration - For Maintenance!Started by Guest_panagiotis_e_* , 11 Jul 2024 |
Gas Seal In Hydrogen Vent StackStarted by Guest_Afshin445_* , 27 Dec 2023 |
Requirement For Hydrogen (Pressurised) Gas Storage BlowdownStarted by Guest_panagiotis_e_* , 30 Nov 2023 |
