Cost Estimating Gas Turbine & Gas Engine
#1 bilel
bilel
Posted 29 November 2012 - 05:20 AM
how can i estimate the cost of a gas turbine and a gas engine with a power generation of 4 MW?
Posted 29 November 2012 - 07:48 AM
Bilel:
If you are an industrial professional engineer, then there is no quicker, more accurate, and more effective way to generate an estimate than to pick up the phone and call a representative of the manufactuer's you have in mind or that you have already pre-selected as acceptable for a serious quote.
This is the way I do it, and the way that most engineers that I work with do it.
Of course, it is smart engineering to make that call only after you have generated an accurate and complete Data Sheet that you should submit.
