Designing Of Fire Tube Boiler Using Asme Standards
8 replies to this topic
#1 engrahsan
engrahsan
  • 7 posts
Posted 03 December 2012 - 12:30 PM
sir,i am designing a fire tube boiler plz help me....give some links or books
Edited by engrahsan, 03 December 2012 - 12:36 PM.
Posted 03 December 2012 - 01:10 PM
The ASME code was put together precisely to ensure that all Steam Boilers in the USA were designed in a safe and secure method and that their operation would result as a safe and steady one.
Therefore, it is precisely the ASME power code section (for fired vessels) that is recommended as the best "link or book" to follow and apply to such a mechanical design. Of course, in order to first be able to read, understand and interpret what the ASME code states requires a professional engineering degree at the very least. And even with a full understanding of the code, one has to have a minimum amount of practical, hands-on, mechanical design experience in designing boilers in order to ensure that the design will actually work, produce steam, consume the required fuel, and operate as specified. Like everything else in the engineering world, it isn't going to be easy or cheap to acquire such skills.
#3 engrahsan
engrahsan
  • 7 posts
Posted 05 December 2012 - 07:16 AM
plz give some links or books for ASME standards to design a boiler
#4 Art Montemayor
Posted 05 December 2012 - 07:40 AM
Go to:
http://global.ihs.co...input_doc_title=
#5 engrahsan
engrahsan
  • 7 posts
Posted 05 December 2012 - 10:12 AM
plz give some books name??????????
#6 Art Montemayor
Posted 05 December 2012 - 11:47 AM
Engrahsen:
2013 ASME Boiler and Pressure Vessel Code
#7 engrahsan
engrahsan
  • 7 posts
Posted 10 December 2012 - 02:12 AM
sir, plz tell any free download link?????????
#8 Shivshankar
Shivshankar
  • 257 posts
Posted 10 December 2012 - 02:55 AM
Hi engrahsa,
http://www.cheresour...-boiler-design/
Please find above link, you can find some book names as reference and you can start up desigining fire tube boiler.
when you face difficulties in designing, you are welcome again, Art and other forum members will glad to help you.
Shivshankar
Edited by Shivshankar, 10 December 2012 - 02:56 AM.
#9 kkala
kkala
  • Banned
  • PipPipPipPipPip
  • 1,939 posts
Posted 10 December 2012 - 12:21 PM
In addition to above posts, you can look at http://www.nationalboard.org/index.aspx?pageID=134&ID=286, or even at http://www.cheresources.com/invision/topic/16607-firetube-waste-heat-boiler (though specific for waste heat boilers), as an introductory material. Searching for "water tube boiler" in the forums will reveal more data, potentially of interest.
More information would result in more specific answers. For instance, boiler capacity, pressure of produced steam, etc, would be useful to be known. Besides, do you want to elaborate mechanical design of the boiler or just a process duty specification for vendors' info / requisition? In the second case you have just to mention the code, otherwise ASME code needs long study for familiarization (Mechanical Dept, not Process, is locally knowledgeable about this code).
Edited by kkala, 10 December 2012 - 02:27 PM.
