Chemcad Sizing
sizing chemcad absorber scds
#1 Aaronicus
Aaronicus
Posted 13 December 2012 - 10:15 AM
I'm currently working on a final project. I have an SCDS column currently set up as an absorber. The feed is a product from a gasifier (CO2, H2, CH4, and CO) and the absorbent is a model of oil (C11-C20). The column works fine, converges, no errors or anything. But for some reason, when i try to size it, i click through the windows of options, and then ChemCad just sits there. It doesn't output anything. Does anyone know why this happens and/or what i can do to fix it? I've attached the file, all the way left i was experimenting with a straight tower and couldn't get it to work, the middle is just the absorber, and the right is the entire process i'm working with (edit: i don't think i can upload the file, sorry). Thanks a bunch
Aaron
#2 Bobby Strain
Posted 13 December 2012 - 02:57 PM
I wouldn't use the sizing in Chemcad. Instead, go to the Koch website and you can download a good column sizing program. If you want to use the Chemcad routine, go to their website and ask for help. Or, read the manual.
#3 ezralh
ezralh
  • 32 posts
Posted 18 December 2012 - 02:12 PM
You cannot do the sizing if you choose SCDS, try tower instead.
#4 Linton
Linton
  • 3 posts
Posted 06 May 2013 - 09:46 AM
Aaronicus, are you still working on this project?
ezralh - you can do sizing on both the SCDS and TOWR UnitOps in CHEMCAD.
