Hi everyone.. I've done a quick google search but can't find what im looking for.
What does it mean by a 'control valve sizing' and what does a 'control valve sizing program do'... what does the program size?
When i googe it i find programs to do it for me but im not even sure what its meant to do..?
Hope someone can help me!
Control Valve Sizing?
Started by Brightonnk, Dec 17 2012 10:47 AM
Posted 17 December 2012 - 10:47 AM
Posted 17 December 2012 - 05:37 PM
Go to the Emerson site. All you need is there.
Posted 18 December 2012 - 03:56 AM
I hope that you know that flow through an orifice results in a pressure drop, and that for a given flow rate the smaller the orifice the larger the pressure drop? Once you have mastered that concept, think of a control valve as a variable area orifice. As the valve opens and closes the flow area through the valve changes and, again for a given flow rate, the pressure drop will vary.
Valve sizing is simply the process of matching your available pressure drop with the actual pressure drop through the valve at a given flow (or range of flows). The Emerson book you found (which used to be on every engineer's bookshelf, but now sits inside their computers) will tell you how to calculate the size of the valve (called its Cv, and explained in that book) for the pressure drop you require. The maximum Cv of the valve depends on the size of the valve and the valve's internals (also in that book). The Cv of a particular valve at any time depends on its degree of opening - you guessed it, also in the book. The relationship between the valve opening and the resulting Cv is called the valve characteristic.
By adjusting the position of the valve you change the Cv and the pressure drop, thus allowing you to change the flow rate through the valve and your equipment.
Posted 18 December 2012 - 04:07 AM
Thank you- you've told me everything I need to know!
Posted 18 December 2012 - 04:26 AM
Check below link
http://www.cheresour...ve-calculation/
http://www.isa-is.or...rary_valves.htm
Shivshankar
Check below link
Shivshankar
Posted 19 December 2012 - 05:51 AM
So many great websites- Im spoilt for choice! Thanks everyone
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , Today, 10:13 AM |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
