According to the specs, MC-250 have a minimum temperature of 66C as flash point (open cup).What is the maximum allowable temperature for sending MC-250 to storage tanks (production unit plot limit condition)?
Mc-250 Storage Temperature
Started by daffe, Dec 18 2012 12:08 AM
Posted 18 December 2012 - 12:08 AM
Posted 18 December 2012 - 06:07 AM
I do not know MC-250, but local "heavy" fuel oil has also flash point 66 oC (minimum) and storage temperatures up to 60 oC, maintained by heating coils and temperature control in cone roof tanks http://www.cheresources.com/invision/topic/9571-npsha-for-fuel-oil-centrifugal-pump/. Nitrogen blanketing would be applicable in cone roof tanks for higher temperatures.
Floating roof tanks should be used, if vapor pressure is about 0.75 - 13 psia at max operating temperature, http://www.cheresources.com/invision/topic/9948-storage-tank-requirements-vapour-losses/, where the restriction "max operating temp+margin < flash point" is not necessary.
Edited by kkala, 18 December 2012 - 06:25 AM.
Off Spec Condensate Storage TankStarted by Guest_shekhar dhuri_* , 05 Sep 2013 |
Flowing Temperature- PsvStarted by Guest_stu_* , 17 Feb 2025 |
![]() Butadine Storage And HandlingStarted by Guest_engmmostafaa22_* , 08 Feb 2025 |
